302 engine dont know the year but its out of a older truck
what do i need to do to make this work with my c4 trans. The
302 engine has 4 bolt pullys can i just put the pullys and flywheel,harmonic bal from my 289 on to this 302
Make sure the 302 isn't the late model 50oz balance, cause if it is you will need to get a new flywheel.
You should be able to find the casting numbers on the reaer of the block. Ford parts are easy to tell the year:
the first letter: C= 60's, D = 70's, E = 80's, F = 90's
the 2nd number: equals the year... So, C7 is 1967
Everything is a direct swap: intake, exhaust, etc. However the balancing is the question. 28oz vs. 50oz.
