1 - 12 of 12 Posts
I have had a bit of a vibration , so decided to get my styled steel wheels balanced. The repo 66 rims are said to be lug centric balance , bot noticing that there where no outer weights on any made me wonder. Anyways the shop that installed the tires thought they would give it a go. They tried one lug and it started to turn, then that was it. Tried another ...no go. The first one was actually hot. They stopped and I too the car home and with a hand wheel lug tool broke off three. This is strange . Now these are 1966 mustang front disc brakes. The rotors are not that old and why the nuts broke....? Poor quality or is it a heat cycle thing. Found some rotors local for $1.11 each Is that a good price. I really don't think I cross threaded them. :frown:..... Any suggestions:)
Greg
$1.11 for a new rotor is a good price.
+1. LOL
I bought my rotors from Advance Auto a few years ago and have had zero issues with them. I always use a torque wrench set to 100'lbs when final tightening.
You can buy those rotors much cheaper. Where are you Europe? Just replace the broken lugs.
No I am in Vancouver Canada. I have lot's of choices here and I did just pound the broken studs. Not sure where to get them but I will look around.
Greg
Banned
Greg
try any parts store or replace with longer race type studs and new lugs . long type can be shorten
Well after a long process of elimination I realized that I never touched the lugs , itw as the front end shop that had done the work last year. Mmmmm. They might have been put on wrong with the impact gun which I do not use. I have always gone with finger tight and then I have used the wrench by hand. Anyways the rotors need to be turned and while I am there I may as well change the bearings and seals ....so I have new rotors coming...
Greg
Discussion Starter · #11 ·
Picked up new rotors , bearings, seals, and wheel bearing grease. Now after I pack the wheel bearings I have to install the bearings and seals. I read that you have to seat the bearings at torquing them at 17-25lbs then loosening them and torquing them to 10-15lbs. Does this sound correct. Then install the cap and cotter pin..
Greg
Greg
Close. What does your Ford Service Manual say?
1 - 12 of 12 Posts
