Discussion Starter · #3 · (Edited)
1963 galaxie has 352 and a three on the tree and I want to change it to
a cruise o matic with the auto shifter on the column.......
column
shift linkage
tranny cross member
brake pedal
tranny cooler lines
tranny kickdown
thanks for your help
Crossmember is the same. Brake pedal arm is the same just the pad is different. I've done this swap a few times (like 10 or 12). I've gone from stick to automatic or automatic to stick. Pm me and I'll walk you thru it. I might have all the parts you need except the transmission. I usually use a later trans (C-6).
