Hi, I'm in a process to switch my 289 for a 390 in my 65 as a winter project, My car is a 3 on a tree. I want to know if my transmission and clutch will work with the fe bellhousing?
thank's
Transmission should work if you use the FE bellhousing and corresponding flywheel, etc. I would rather put a 4-speed Toploader behind that 390 though.
See attached below input shaft details of the 3.03 3/S. You will also need to go with a larger dia. clutch asm.
