I have a 302 Engine that has the numbers casting D2C and EOVE above starter boss and on the machined pad in the back of block on top stamped EF203.Anyone decifer that for me?It also has no threaded hole for pivot bar.Thanks
E0VE tells me it is a 1980 302 block
Thats is what I thought but it has a one piece crank seal on the back.I have the flex plate that was on the engine so I took it down to machine shop to have the 164 tooth clutch flywheel imbalanced the same.Probably a 50 oz but they will match.Not that "HEP" on Ford stuff so a learning curve for me.Thanks
