Hi there I'm looking for some help and will try to give you all the info I have i have a tired 302 basically stock I have headers and 1.6 trick flow roller rockers and b303 cam... I'm drag racing the car now and am going to do a rebuild in the winter...i have a new victor efi upper and lower as well...im looking to go 11s what would you do to run 11s it would be a track car with very very little street time..im also looking from room to improve the build so possible keeping a compression that could have add a blower... would you put a stroker change block to 351 and sell all these parts....thanks car is a full interior car for now with 3.73 gears and completely rebuilt rear end good to about 10 . 90 with a t5 also has radials...drag shocks and skinnys
hi I'm chris I will give you a 7.80 @ 93.8 mph with a 1.8 sixty foot I know it sucks 1/8 mile combo that is a 11 sec 1/4 mile car 1988 coupe with 3.73 gears 5 speed t5 stock rims and 15 inch tires stock 1988 302 roller block with flo-teck 180 cc heads a 1.94 1.54 valve package 600.00 bucks some places sell them in the 580.00 range comes with one year warranty and trick flow stage 3 cam and springs 300.00 bucks cheaper if found used a funnel web intake 150.00 bucks [cheaper if found used] demon 750 carb 200.00 bucks off ebay worked perfect square jetted 84-84 jets front and back no power valves at all ebay 1 5/8 long tube headers 150.00 bucks cheaper if found used. a distributor for a 1985 gt mustang with steel gear new 60.00 buck used 20.00 bucks from junk yard a HEI module from a 1978 Camaro new 20.00 buck its a 4 wire hook up two wire to coil to wires to distributor same insides that msd uses on the 8598 racing distributor a you can use the coil you have now. so for 1480.00 bucks you have a 11 sec combo if you by used stuff you could get away with 1000.00 bucks total that is the build I did last year it worked perfect if I would of changed anything I would of put 3.90 gears in it that's it
