Any comments?
302 + 0.030 over
1969 351 Heads ported
XE 274 Camshaft
Performer rpm Intake
9:1 Compression ratio
600 cfm carburator
Thank you for you help in advance!
Terry
N2O Mike just curious why you thought that cam was too big for my combo.The only difference is the 351 size valves versus my 302 size valves and I think I have a touch more compression.You recommended the XE-268 for mine while the comp cams guy recomended the XE-274.I just want to be sure I get the most performance possible. I was thinking of getting the larger valves but was going to change the cam instead,(costs about the same)What should I do?Sorry I know I'm from the old school bigger is better way of thinking but I don't want to be undercammed
Oops, you got me. I was just getting ready for bed, going off memory, and the head wasn't 100%.
I recommend the one with 224/230 @ 0.050" for up to around 6300-6500 rpm........ which would be the XE268.
If it's not going to be revved over 5800rpm, I'd even go with the XE262 which measures 218/224 @ 0.050".
Those factory tech guys are used to recommending cams for 350-400ci chevy engines, and will usually choose something too big for a 302.
Good Luck!
Mike Burch, 66 mustang real street
302 4-speed 289 heads, 10.63 @ 129.3
http://www.geocities.com/carbedstangs/cmml_mburch.html
http://www.fortunecity.com/silverstone/healey/367
<font size=-1>[ This Message was edited by: n2omike on 5/20/02 7:28pm ]</font>
