Hello, I am starting my first top end rebuild of a 302.When finally taking the heads off coolant came out and poured into the cylinders, I am assuming I did something wrong when draining the radiator.can anyone advise me of what I did wrong and is this a problem?
Happens more often then not.. Soak up all the coolant that you can, if you have an airhose you can blow dry with 20psi or so. Wipe a little oil on the cylinders..Make sure you drain the pan and replace witih fresh oil when you put it all back together.
