I have a lead on a 1976 302 to go in my Falcon, but it is a marine engine. The seller says those 302s were HO with steel sleeves & steel cranks. Anybody familar with these engines? What needs to be changed for street use? Thanks for the help.
Would they have also done some type of coating inside the block for corrosion?
John
188 hpany numbers on the valve covers
Thats what I was guessing but not sure as they changed severl times over the years. Think just changing to a 4bbl it was rated at 235 dont think the cam was different. Marine cams are a bit more like towing cams a bit more duration @ .050 and a bit more lift. Often similar to the high speed towing grinds. I dont think I have any records as to the grind used back in those days. Mercury Marine would never divulge torq numbers.188 hp
