Hi, well how much Horse Power and how high rpm can you get out of it. with 2.02 - 1.64 valves and World Produt heads and 13.5-1 comp
and a 850 dp. carb
or give me a good combo for a 302 no bottle
Its a lot easyer to replay if you tell more about your setup in a ?lbs car, and if it is a street or drag driving. !
OK It's a 302 + .030, vic jr intake 850dp or 750dp holly, crane cam [email protected] 591 lift 106 cl. manley rods,wiseco lw piston set up for WP heads 13.5 to 1 comp 2.02-1.64 valves
2800lbs car four speed. 564 rear gears 12.00 x 29.5 x 15 slicks. will this help the cam can be changed we are open to that. and it is a full drag car.
I had basically the same engine in the old Maverick. 9.0's @ 110 mph at a 1000' track, 1/8 mile was 6.95-7.10 depending on weather. 60' was 1.45-1.50, again depending on weather. Car weighs 2600 lbs w/ driver, 4.86 gear, 4200 stall 9" converter w/c4 trans. Hope this helps. I had performer rpm heads, slightly ported, polished chambers and exhaust ports. Cam was a lunati 254 @ .050, .542 lift (smaller than the one you will be using). Also used those heavy trw L2249 pistons, 11.0 compression.
ok I ran that throught desktop dyno and you get 499HP at 7000 and 398 ft/lbs at 6000
this was assumeing large tube headers and I guessed at the intake and closeing of your cam
hope this helps
