with a c4? will it work? i ave a truck i need to get on the road, and yes this is low on torque for the heavy truck but i will oneday supercharge it. i just need to get it up and running cause the guy that is holding it for me needs the space, and i have a spare c4 and 302. whaddayathink? thanks
sure it'll work. Frame mounts form a 70s F series with a 302 should bolt right in making for a rather easy swap.
You should be able to find engine mounts from a 1970-79 F100/F150 in a pick-a-part type yard in your area. You can reuse your old tranny crossmember with the C4.
