1 - 13 of 13 Posts
Figured Id make my first post on here a good one. lol. Picked up a 68 Galaxie a few months ago and decided to turn it into a "sleeper" if you will. I had the 302 motor inside it rebuilt and added a new cam, new heads, new intake man., headers, rebuilt Holley 650, you name it. I have all of the detailed specs on the parts if needed for reference. However, the one part that I did not replace but rather had installed was a point-style distributor. This motor should be a little fire cracker of a motor but it runs like grandmas car.
Next are the problems I am going through right now...
Stalling at lights, rough idle, backfires, misses, idle changing from one day to the next, sluggish...
No smoke, no leaks.
I understand that these symptoms could be many things but so far, from the many people Ive spoke with, all indications lead to changing to an electronic ignition with no points.
We also found that inside the distributor the advance wasnt working properly. It would not retard all the way back. Hit it with some lithium grease and seemed to work better. This is another reason for leaning towards a new distributor.
Any and all thoughts appreciated!!
The dist is fine, change the vacuum advance can and lube it all when you're doing it.
Then either put in NEW points or properly gap the already new points and them and set the dwell.
Then re-time the engine paying attention to the full timing curve and where it happens. Make everything happen when it's supposed to and all will be copacetic.
X2
My 302 must have made twice the trq, more hp down low, and has throttle response better than most new cars when I finally got my timing curve dialed.
easy way out is spend 35$ and get a new points style dist, then if you want to upgrade from there you can use a pertonix unit.
Thanks for the great info and rcomendations! Makes perfect sense now...Ill post up some progress on this motor by this weekend.
I will get the specs of the aftermarket parts up tonight as well.
Sent from my iPhone using AG Free
X2
I'm with redtail on this one. So many things can be wrong with an old points type distributor. Get a rebuilt body and drop in a Pertronix kit. You'll never need to open the cap again and it will run great.
John
I totally DISAGREE.
Only THREE things can go wrong with a points style dist that Cannot go wrong with an Elec. pickup in the dist.
1: Points can fry----- Electronic pickup can fry!
2: Condenser can go bad and suck up all the spark or not suppress enough and burn out points early--- Elec has no condenser.
3: The Ground Strap can fail and give poor spark jump----
So let me correct you AND Me, there is only ONE (1) advantage in using electronic over points... But wait! There's MORE!
Points WILL NOT FAIL without giving notice of failure in the way the engine runs. Electronic pickups will simply stop your ass where you are at that exact moment when they fail. Points going bad will allow you to drive almost forever. ANd the ground strap failure is so extremely rare as to be almost unheard of.
SO! Allow me to allow myself to let you in on the one statement that's true in the difference in the two types of spark delivery.
There is ZERO advantage to points in your dist over pertronix EXCEPT for the QUALITY of the Spark. If you aren't racing your engine for every N~th of energy you can get with it, Points will work fine.
Let any who say NAY please esplain themshelves... :D
I totally DISAGREE.
I ran points for a long time and never had issues with them. I have heard they can burn out if you leave the key 'on' while you are listening to the radio, but I never had that issue.
HOWEVER, I did notice the engine seemed to be a little more even and smooth at freeway RPM, and at least with my pertronix III unit I now have a rev limiter. However none of this makes the truck run THAT much better. $100 could be better spent elsewhere, but it is nice to upgrade things, as with my unit I can have an MSD 50,000V discharge that fits under the cap and looks stock.
All that said get a new points style dist (as the bushings and other parts on the shaft wear) and just adjust it and run it! somehow they made big HP in the 60's, and we can do it now.
Discussion Starter #10
Greatly appreciate all of the feedback from you guys. Seems to be narrowed down to the distributor being the break in the link here. I also wanted to post the individual parts that I bought and installed onto the motor to see if any difference in timing adjustments or adjustments in any way needed to be made with the addition of these performance parts.
Heres the links to the specs on the parts that I have put onto the engine. Maybe this can bring out some different answers or show what the problem is right away. I know for a fact that the point stlye distributor installed is a cheapo brand I've never even hear of that has been adjusted and readjusted already and has a vacuum advance that has trouble retarding. I should have posted this paragraph in the first place.... Being these parts are more perfomance that the stock parts I removed, I also thought that the timing degree and distributor setup, as well as carb tune would be different.
Timing chain
COMP Cams 2120 - COMP Cams Magnum Double Roller Timing Sets - Overview - SummitRacing.com
Camshaft
COMP Cams CL31-238-3 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
Heads
Edelbrock 5025 - Edelbrock E-Street Cylinder Heads - Overview - SummitRacing.com
Intake Manifold
Edelbrock 2121 - Edelbrock Performer Intake Manifolds - Overview - SummitRacing.com
Transmition is a C-6
Rear end I "believe" is a 9'' and has low 300's for gears.
Points style distibutors work just fine if everything is in good shape and properly adjusted...However most people can't be bothered taking the time to keep things adjusted...If your distributor is an aftermarket points style is it at least a high performance type distributor?...Something like Accell or Mallory?..Hopefully not some cheap Chinese peice of crap?...
Discussion Starter #13
Definitely a piece of crap off name brand style...
1 - 13 of 13 Posts
