I have a 302 that I am trying to tune and it has me a bit stumped right now. Been tinkering and haven't been able to get it dialed, hoping someone might have some thoughts. Here's my specs:
-302
-E-street aluminum heads with roller rockers
-Dual-plane aluminum intake
-4-barrel 670 cfm Holley (vac. secondary) with #65 jets
-Ready-to-run distributor, 8.5mm 50 ohm wires, 8-deg base timing, 24-deg at idle with vac advance, 40-deg total advance
-Champion plugs gapped at .040
-MSD 6AL
-31-242-3 Comp Cam
-Full-length headers with 2.5" dual exhaust
It idles fine and off-idle acceleration is fine but I have a hole shot stumble (launching at about 1500-1800 rpm) that I can seem to fix and at about 3000 rpm it will start breaking-up and backfire through the exhaust revving it in the garage. Haven't had a chance to try it at the track to see if the breaking-up improves with the scondaries coming in. Plugs look like it is running super rich no matter what I do.
I have tried changing main jets, timing, plug gap, mech. advance springs, accelerator pump nozzles, accelerator pump cam, and hooked up the vac advance which was previously unhooked. Nothing has resulted more than a minor improvement so far.
-302
-MSD 6AL
-31-242-3 Comp Cam
