I have some doubt about a upgrade that i want to do in my Maverick.
I want to use a Edelbrock intake and headers and all hardware, holley 600cfm carburator and eletric fuel pump, MSD ignition - all hardware. I have a doubt about what radiator i can use. I will use a water pump by Weiand.
Please tell what else can i use in this configuration.
Thank you very much and about my english, MadMaverick.
You need to go to www.maverick.to. The people on there will be able to answer just about any questions you may have. There is also a section on Brazilian Mavericks.
I have a 69 Fairlane that had factory air, doesn't now, will again one day.
I have a 408 stroker in it now, and I want heat inside the car. Until now nothing was connected to the heater core and water pump and thermostat housing were all plugged. There are 3 pipes to the heater core on the...
Hi I've got a 1982 ford Fairmont with the straight 6 in it I was wondering what's the easiest engine swap I could do with her and maybe get a bit more power thanks
Tearing my engine down for an overhaul. It’s a ‘62 221 V8. Things came to a halt when I ran into this. Was this a factory bolt head design, or switched to when engine was rebuilt 40 years ago?
Who makes a bit for these? I saw nothing online.
BTW, Argh!
Does anyone know what this might be? At the tip of the screwdriver - I put in the stainless bolt. It was an open, threaded hole that puffed smoke.
Did not see oil or any other fluid coming out. It only puffed smoke. Strange.
Could this be a port to the exhause passage for a hot air choke...
