306 combo ! How much hp ??
It's a 10.8.1 306, old heavy trw forged pistons, Canfield 192 heads, out the box, 194, 160 vlave's, 1.6 scropion roller rockers , Edelbrock performer Intake , 70mm BBK thottle body, 76mm C&L mass air , custom hdy roller cam from cam motion, but it was cut for a carbed setup and Dart Sr. Heads, spec's are
lobe Seperation= 110.1 Cam Deg
Valve Overlap = 1.9 Crank Deg
Intake valve open = 4.9 'BTDC
Centerline---> 106.1 'ATDC
valve close = 35.3 'ABDC
Duration-----> 220.2 Crank Deg
Lobe Lift = .33866 In.
Valve Lift----> .54186
Lobe Lift = .25.91 In * Deg
Exhaust
valve open = 47 'BBDC
Centerline---> 114.1 'BTDC
valve close = -3 'ATDC
Duration-----> 224 Crank Deg
Lobe Lift = .3378 IN.
Valve Lift----> .54047 IN.
Lobe Lift = 26.3 IN * Deg
Let me know what you think. Any suggestions would be appreciated, thanks Jeramie.
