331 stroker shortblock never been used, Sitting on engine stand in heated garage. Over $5000 invested with receipts. Please make me an offer as I am getting divorced and must sell. All parts are new and was built by reputable machine shop in Victoria.
331 Stroker (5.0L Roller Block)
Eagle stroker kit (I beam rods, SRP forged pistons, Eagle crank)
Comp Roller Cam 281HR
Arp Stud Kit
Moroso Main Girdle
Edelbrock true roller timing chain
SFI balancer (Proffesional Products)
HV oil pump
Machine Work = Hot tank and sonaflux block,Install main girdle,check dech heights,align hone block with girdle,torque in bearings to determine final housing bore size, bore & hone block with torque plate,clean block after machining,deburr block & tap front oil galleries,re&re frost & oil plugs,check wrist pin clearance in pistons & rods, Install pistons on rods & check alignment,install ARP stud kit,install roller cam (281),lifters,bearings & degree cam, engine balanced.
Please make me an offer, Will sell for fair price. Add your cylinder heads,carb,intake ect and your off to the races with a very strong shortblock. Please call Shawn at 778-678-1977, Or sent me a private message here. Thanks.
I am located in Canada (Victoria BC)
