Hi i have a 331 stroker with low compression. Was lookin at buying a vortec v2 makin 18psi of boost was wondering if it will run 10.50 in the 1/4.. and will it make to much HP to break the stock block
Easily - if done properly.
Easily - if not done properly. The 'typical' 331 with 18 psig will generally make more power than you'd need for 10.50s in a 2800-pounder, and would also exceed the stock block's limits. You should be able to run less boost to hit your ET goal, and not break the block. Don't try to use power to make-up for an un-tuned chassis, mis-matched parts, or driving technique. It rarely works well and tends to break parts.
