this was a 347 pro comp 205 heads, trickflow cam .565 lift in a 1994 ext cab ford ranger. with the junk pro comp heads best pass was a [email protected] mph. the truck was 3280. i have a chart thing and it say that it would be about 288 hp to tires. the motor got hot so i took it apart and found the heads was trash. i went to a solid roller .675 lift cam, dart pro 1 non ported heads. the motor made [email protected] on a engine dyno. this is a stock block with a main cap support,h beam rods,4340 steel crank,around 12.5 comp
