Ive recently put together a nice 347 combo for my foxbody, I dont have access to an engine dyno and Im not interested in tuning the car on the chassis dyno this time of year because up in Ontario Canada we get some chilly weather, so id just have to re tune the car in the summer. anyways, heres the setup:
E7 block 4.030, .00 decked
probe forged h beam rotating assembly, flat top 10:8 (give or take) pistons, forged
double roller timing chain
comp cams xfi stroker cam, .608/.608 248/258 @.050
short travel race lifters
ported original tfs high port heads, 2.02/1.6 stainless valves 1262 gasket, 1415 exhaust flowed 295+/- intake and 220 exhaust.
comp ultra pro mag rockers (black ones)
987 springs
race ported victor jr intake, wilson manifold big 4 hole spacer, full plenum port and 1262r gasket match, fully polished
1 3/4 headers and 3 inch exhaust
850 mighty demon carb
high flow oil and water pump
what everyones guestimation as to the hp at the wheels? driveline is 31 spline 8.8 rear with 4.56 and spool, t5 trans, alum driveshaft, 28oz steel flywheel with king cobra clutch. i say about 410hp through the exhaust rear wheel at 6500+. 375 torque.
when i do dyno the car i will post dyno sheet to see who was closest!! cheers!
987 springs
