Hi all,
I am in the process of building a 347 stroker and don't know what to expect in terms of power and torque. I also have yet to buy a torque converter because I don't know what I need yet. My build is as follows:
94 mustang GT with 347 short block with scatt stroker kit, Renegade AFR heads with 165cc intake and 58cc combustion chamber (all CNC ported), trick flow track max stage 2 cam, street burner intake, 75mm throttle body, BBK cold air intake, 76mm MAF matched with 30lb/hr injectors, new fuel pump, AODE trans rebuilt with shift kit, B&M shifter, MegaSquirt Gen 2 ECU, underdrive pullies, 3.55 rear end gears, full magnaflow exhaust and BBK headers. What should I expect for ballpark power and torque?
