347 windsor
dart snr's
10.1comp
comp cams 294's
quad 44mm idf webbers
1 3/4 headers 4 into 1 2.5 dual
295rwhp/5600rpm max(started pinging and leaning out)
355ftlbs max torque
when is gets dyno tuned this friday coming i will post the (hopefully increased hp figure)
Your numbers nearly mirrored mine. Max Torque = 358.5 @ 3500, Max Power = 289.6 @ 4600. Only had two pulls back to back on the dyno,leaned out ... raised the fuel pressure up a few lbs and felt a noticeable driving difference but couldnt get the number results.
