Hey all, I'm new here so I thought I'd introduce myself first off.
I have been searching this forum and others looking for the best possible combo to put together a B-mod/Midwest mod motor. I am planning on running at Lucas Oil Speedway in Wheatland,Mo. Rules are fairly straight forward but like a lot of places they are predominantly based around them damn chebbies.
Here are the engine rules:
ENGINE
SPEC ENGINE: Must use OEM cast iron, American made V-8 engines only. All engines must be able to be used in conventional passenger car without alterations. External engine casting and threaded holes cannot be altered. No aluminum, titanium or carbon fiber components allowed. Maximum cubic inch limits: GM 361 c.i., Ford 360 c.i., Chrysler 370 c.i., no tolerance. No 400 or larger cubic inch parts allowed. Engine must appear strictly stock. No lightening of block allowed. No lightweight rods or crankshaft. Crankshaft must be stock appearing. No pendulum cut or holes across counterweights. No aluminum or lightweight engine parts allowed. A minimum 1-inch plug above the oil level in the side of the oil pan recommended. If you do not have a plug the oil pan the pan will have to be removed at time of inspection. You will be checked. Flat Top or Dished Pistons only with a maximum Compression Ratio of 10.5:1 including Chevy, Ford, Chrysler, and Dodge.
CRATE ENGINE: Unaltered sealed GM crate engine #88958602. Any different, altered, or missing GM seal bolts will result in disqualification, loss of all track points for the season, and a one year suspension.
VALVE TRAIN: Maximum 2.02-inch intake valves and 1.60-inch exhaust valves. No titanium valve springs or retainers. Guide plates and screw in studs allowed. Flat milling allowed, No angle milling allowed. Flat- top or dished pistons only. Must use flat tappet cam and lifters. No mushroom lifters. Cannot alter lifter bores. Must use OEM size lifters for block being used. Any length push rods allowed. Aluminum roller ocker arms and stud girdles are allowed. No canted valves. Inline valves only. Maximum valve spring diameter 1.440-inches.
BLOCKS
GENERAL MOTORS: Must be 3.48-inch stroke and 4.060-inch maximum bore. Maximum 360 cubic inches. COMPONENT GUIDELINES: Must use one of following blocks, 3892657, 3914678, 3932388, 3932386, 3956618, 3970000,3970006, 3970010, 3970014, 10066033, 10066036, 14010207, 14010209, 14010287, 14016376, 14016379.
FORD: Stock cast iron blocks 260, 289, 302, 351. Maximum 360 cubic inches. No aftermarket blocks. CHRYSLER: Stock cast iron blocks 273, 318, 340, 360. Maximum 370 cubic inches.
HEADS: These are the only legal heads!!!
GM: Any stock GM head. No bowtie vortec heads allowed. Dart - 10320010 or 10311112
World Products - 011250 or 012150
RHS - 12319 or 12320
EQ - cc200BA Bowtie - 034 Standard Vortec
FORD: Any stock Ford Head
World Products - 053040 or E351 or Roush 200 RHS- 35302
SVO- N351 or N352
CHRYSLER: Any OEM factory production Chrysler heads allowed with inline valves (no canted valves) no larger than 2.04-inch intake and 1.70-inch exhaust. No W-2 or aftermarket heads allowed. Chrysler may use OEM rocker arm bars.
No aftermarket head other than listed above allowed.
Track has option to enforce these restrictions with a cubic inch pump gauge, or by visually checking parts and part numbers Disqualification and loss of points may result if found illegal.
CARBURETOR
SPEC MOTOR: Must use stock Holley 4412 500 CFM carburetor only. No Modifications. Choke horn must be intact. May remove choke butterfly. Must use Edelbrock Performer 4 bbl. intake manifold. Chevrolet part #2101 or #2116, Ford part #2121 or #2181 or Chrysler part #2176. NO exceptions. No Performer RPM or air gap manifolds. Must use Mr. Gasket part No. 1933, Moroso part. No.64966, Speedway part No. 910- 11510, or HVH part. No. 4412-2 carburetor adaptor. No spacers are allowed. Carburetor and adaptor gaskets maximum 0.050 inch thick.
CRATE MOTOR: May use any Holley 4 barrel carburetor; all components (float bowls and main body) must be Holley manufactured. Metering blocks and base plate may be billet aluminum non-Holley. No aerosol-style carburetors allowed. May use one inch thick carburetor spacer, must use Moroso part #64940 or a 2" open plastic spacer allowed with GM crate. Maximum 0.100-inch thick carburetor gaskets only.
OIL PANS - Extra capacity oil pans are permitted. No dry sumps allowed. Oil pump must mount in stock position.
STARTER - Engine must have working starter and must be capable of starting car on demand. No Reverse Mount Starters.
GAUGES/ELECTRONICS - 12-volt ignition system only. All wiring must be visible for inspection. The only gauges allowed are analog oil pressure, analog water temperature and analog tachometer (memory recall allowed). No electronic traction control ALLOWED.
GM: HEI distributor. OEM firing order cannot be changed. Ignition rotor, cap, coil and module must remain OEM appearing.
FORD: Duraspark distributor with stock type coil or HEI
CHRYSLER: Ignition rotor, cap, coil and module must remain OEM appearing.
All cars may use a Part # MSD 8728 Soft Touch Rev Control box. Must be mounted out of reach of driver. 602 Crate Cars must use a Part # MSD 8728 Soft Touch Rev Control box mounted out of reach of driver. 602 CRATE mandatory 6200 RPM chip. Track reserves the right to swap or exchange chip at any time.
I am not very experienced with the Windsor stuff, most of my knowledge is based around 429-460 stuff so I'll take all of the help and suggestions I can get from you all. I want to build theist competitive motor that I can for this upcoming season.
Taylor
ENGINE
BLOCKS
SVO- N351 or N352
CARBURETOR
Taylor
