all the "M" engines use a large bellhousing pattern, the same as a 460. You can spot them a mile away. Also, the cleveland uses the small-block 2 bolt engine mount, whereas the "M" blocks use a 3 bolt triangular mount, similar to a 460. The "M" engines are also physically much larger than the clevelands, almost as wide as a 429-460.
