New doesn't mean it isn't full of garbage, seem that a few times. Fuel level can also be so low that a little gas gets in the float bowl and fills the acc pump up, (which sets in the bottom) and that's it. That's the gas you see pumping in when you work the linkage. If the level is so low, neither the idle circuit or the jets will get any fuel to work. Pull the float bowl off and flip it upside down and see where the float sets, take 2 aspirins and call me in the morning.it is a new Holley putting gas into Manifold when linkage worked by hand but car will not run car runs only on gas dumped into carb
So maybe the accelerator is pumping gas but not much. That could be.YES Not a dumb question, just finding someone who grew up and has worked on carbs is hard to find anymore. Holleys are nice, Rochester Thermoquads and Quadrajets, along with AFBs are another subject. Edelbrock carbs are the old AFBs with a chrome finish.
The gas is pumped into the carb's float bowl via the float/needle valve. If the acc pump is getting fuel, I'd say it is pumping in the float bowl. BUT if the float level is to low, it only gets to pump in enough to fill the acc pump's cavity, and some in the bottom of the float bowl, which supplies gas via a hole in the bottom of the float bowl area. Then the float valve shuts the flow to the bowl off.
With a low fuel level the jets, idle circuit and Power valve are all left high and dry. That is why the float level if to low starves the system and to high floods the engine out the booster venturi in the carb's throat.
You can actually mix kerosene and gas and it'll run, just not great. I knew a Utah HP (back in 72-74) driving a 71 Galaxie 429PI (aka 429CJ) that every fill up he put a gal of diesel fuel with the gas. Didn't smoke and always ran great.
It's probably pumping, but remember without enough fuel in the bowl to allow the idle circuit, if it's not plugged up, to work, it won't let it idle or run and any speed. The engine doesn't run off the Acc pump. It runs off the idle and metering system.So maybe the accelerator is pumping gas but not much. That could be.
Sure sounds like it's not getting fuel from carb. I know you said it's pumping in however why does it run out? Is the float possibly sticking closed in the carb? Try running on either just squirting in periodically to keep it running. If it does that then I would say float is sticking closed. Let me know.OK Guys need some imput I have a 1969 351w Has not ran in years installed new fuel pump dist wires installed rubber hose from carb to gas can. pumps gas to carb has spark, vacuum, it will start if primed but quits after prime is burned if re primed same thing carb is pumping into manifold but will not run HELP!! please
Ok I had similar problem on a 5.0 ,, it would fire then nothing... pour enough fuel or starting fluid and it would run a bit... was getting fuel... Pulled the plenum, was full of Mice nests, and had gotten in the lower Plenum/intake... pulled it ... was full of insulation mice nests around the valves and it was saturated with fuel... cleaned and picked it all out and put back together and ran like it was supposed to... now yes this was Fuel inj. but if they got in the intake .. same problem would happen..OK Guys need some imput I have a 1969 351w Has not ran in years installed new fuel pump dist wires installed rubber hose from carb to gas can. pumps gas to carb has spark, vacuum, it will start if primed but quits after prime is burned if re primed same thing carb is pumping into manifold but will not run HELP!! please
