Hi Guys,
A quick question; I have just started the build of my 84' 351 Windsor 393 stroker & am using Tom Monroes "How to rebuild SBF". In his book he shows a crankshaft oil slinger being installed, (sits in between the crank timing sproket & harmonic balancer) however I dont recall seeing one of these when I tore-down the original block. Can anyone advise if I need to install a slinger or is it OK not to??
Any help greatly appreciated.
Martyn
<font size=-1>[ This Message was edited by: martynUK on 5/30/06 12:57am ]</font>
Many later blocks did not come with one. Also many people run without it.
Dennis
65' Stang
393 Stroker, Toploader 4 spd, 9" 3:70 rear.
Victor Jr. Knockoff Heads, 282S cam, Stealth Intake, Bigs Stage 5 750DP, Accufab Headers, Scattershield, Caltracs.
<font size=-1>[ This Message was edited by: dennis111 on 5/30/06 1:25am ]</font>
Leave it out, not needed.
If your timing cover has an oil drain back ledge on the inside you shouldn't install a slinger. No ledge, run a slinger.
