I checked my build notes, and here's what I used on that engine and how I got it:
- Cast steel 4.170" stroke crankshaft - checked for straight and index - minor knifing
- 6.125" ultralight I-beam cap-screw rods @ 557 grams matched to .5 gram (Probe has a very similar rod #10667)
- SRS 12360 pistons (1.280" CH, 22cc dish, 4.040" bore) 545g matched w/pin and rings to .5 gram
- Hastings 2M5523 plasma-moly rings (1/16" torsion high-tensile iron, 1/16" reverse torsion, 3/16" flex-vent std tension oil)
- Bore finish 4-step with torque plate (hone 100g, 280g, 500g, 320g brush finish)
- Decked .011" to square & zero deck
- Balanced assy (pulley to flywheel) to 1.5 gram, no added weight
I did it for the use - efficient power with reliable long life. There are plenty of other choices you could make, but that's what I used to finish the package. I show 116 hours for this build (that's everything - planning, ordering, blueprinting every last part, multiple mock-ups, head work, spring changes, etc.) So, although a relatively inexpensive build, I did everything with the same attention to detail as a pro-level engine because that's just how I work, and I don't have surprises that way. My philosophy is if you build it like medical equipment, it will perform 1st time, every time, for a long time, compared to... a tool from Harbor Fright. It's just my time, and I enjoy it. Some call me anal. That's fine.
My personal opinion - I avoid heavy parts whenever possible. This build has no need for killer rods, and especially sexy H-beams that weigh about 1/4 pound more per rod. In reality, H-beams have rather few applications, and usually only ones that require extreme tensile or compressive strength. We don't have that issue here, and you will generally have higher actual strength and durability with the lightest parts you can use, as the strength to weight ratio is better. Using stronger rods means heavier, and heavier means more stress on the crank, so that needs to be stronger to take it, etc. It gets to be a losing battle if you're not careful. I love ultralight. Think of them as aluminum rods that don't stretch or grow.
Calculating your parts is actually easy. To determine for zero deck, measure your block for deck. Let's say it's 9.500" to make it easy.
9.5 - 1/2 stroke - rod = compression height. So, my combo is 9.5 - 2.085 - 6.125 = 1.290. If you can square the block to 9.490" (and most can), then you are at zero deck with a 1.280 piston. Yes, you could run longer rods, but remember what you're building. With a 6.250" rod, your piston only has 1.155" CH. That means less stability, greater chance for 2nd ring flutter, or the oil rings will go thorough the wrist pin hole if you space the rings apart, or the top land will get scary thin if you space them up. Not good compromises for a long-life engine - or even a power package for that matter. The gains in R/S ratio are lost in off-temp ring sealing or gained back by adding 1 psi to your tires. Not worth it - in my opinion. Same reasoning for opting-out of low-tension oil rings on this street engine.
BTW - there is no fear of using an early short-deck block or if you have to cut more to square your roller block. That's what gasket selection is for. I have a set of .050" head gaskets just for that, so I can use the short 9.480" '69 block I have and still get the same quench as a later block. HTH
