21 - 23 of 23 Posts
Do you need an iron 4V or aftermarket head to make 375HP? No, I never implied anything close to that. My advice was about time and money.
Iron 2Vs have a poor intake short turn radius that isn't easy for a first time porter to get right. Porting is very time consuming...not bad for a DIY project if you have the tools and determination but I wouldn't pay a professional to work on that type of head.
The open chambers are a problem for getting decent compression with a flat top piston. Figure about 9.25:1 tops for a zero decked, stock stroke engine.
Now figure out what you have to spend at a machine shop to get the heads reconditioned. Disassembly, cleaning, magnaflux, resurfacing, new guides, hardened seats, valve job, machining for screw in studs, etc?
I'm not saying it will need all these things...it's just good to be aware of expenses that may be needed to make an old head like new before comparing price to an aftermarket bare head.
I don't think I have to go into the obvious advantages of new technology.
Aus Ford Parts - Aussie 351 Cleveland Specialists
First off 4V heads will kill those heads out of the box, only after you put in $$$$ are they good & you have to run their intake = more $$$
CHI & AFD always do dyno runs against iron heads using a smogged down stock non flowing intake. Put on a Holley or Blue thunder or something else then we will compare.
After market heads WILL make more power but only after you spend alot more money
Doing the heads on a Cleveland gets expensive real quick, Labor is the killer, in a Cleveland head all the Valves have to be changed for the engine to make any kind of HP and not have a Valve drop!
The stock Cleveland valves are the Rotator type wit 3 grooves to hold the retainer! These do not hold the valve tight enough and have a habit of failing! A $200 set of heads will become a $1200 set of heads real fast with parts and labor! that is why After market heads are as popular as they are! To pay someone by the hour to port a set of Cleveland 2V heads is not practical dollar per HP!
21 - 23 of 23 Posts
