Hi.....Can anyone help me with the engine mount bolt holes on the block? On the ford engines are 2 bolt mounting bosses on each side which the motor mounts get bolted to. Can I get the bolt hole centering width wise and the centering length wise? Building a set of special engine mounts. Thank you and have a good day, John
