There's a guy here locally that is selling some 351C 4V heads that he says the coolant ports have been modified to work with 302/351W blocks. I assume using these would require 351C intake and headers.
Has anyone had any experience with this? It seems like they should flow well considering the size of the valves. I find that they should have a 62.8 cc combustion chamber; combined with a piston with a small dish and thin HG's should net about 9.5:1 compression I think.
Also, does the 302's cam work OK? I guess all the lobes line up with the valves on the heads?
In short, would this be a good idea?
