The 69 - 74 blocks are heavier, but the deck height is .023 shorter (9.480 vs 9.503). This comes into play when you are planning your piston deck clearance and quench area. If the earlier heads have been deck milled, and you choose the wrong piston, you may end up with it sticking up above the block deck. Measure carfully and stive for as close to 0 deck clearance as you can get. I used an early block that had not been milled and Sealed Power flat top pistons to achive .002 deck clearance, which is as close as I could get wothout shaving .002 off of the decks.
