:tup: 351W .030 ,Dart iron heads,mild porting,SS valves,Crane roller rockers,Fluidampner,Lunati flat tappet 554 lift,Comp push rods,crower rods,CSR elec water pump,Melling oil pump,Mallory dist,Ford Motorsport alum intake,650 carb, C6 trans w/3500 stall,transco shift kit,and a B&M pro stick shifter w/ cover...In a prostreet falcon show car. Low miles..A steal at $3500.firm.. Can hear run... Will not remove unless deposit is forwarded.Will swap towards New 427W stroker that someone has plus cash. 908-788-3769 :D [email protected] ..NJ...
