I have a 351w which I bought which needs a refresh, and the crank has some major blemishes, if I buy a 3.75 stroker crankshaft and use STOCK 302 pistons and 351w rods would the cr be low enough to run pump gas I know the 393 stroker using 3.85 crank and using 302 pistons need at least a 22cc dish piston using stock 69cc heads. Would the 3.75 crank work to keep the cost down and keep the cr down enough to run pump gas? I know the stock smog heads are a bottleneck but I’m not taking this motor out again and I have to change the crank already so I figured I could put in a stroker if I could if I can keep it cheap enough, it’s for a mud truck I bought for 500$ Not putting much other power adders to it other than camshaft and basic bolt ons.
