$5500 obo
#941-822-3943 Chris
Only used once at the track, several times on the street. Best time was 10.70 in the 1/4, in an 89 LX Hatch. Sold the car have another project and motor so this is for sale. Freshened to sell, never broken. Bagged on an engine stand in my garage, fogged and turned over by hand with Amsoil fogging oil. Throw on a flywheel, Carb of FI and you're done. Prefer pick up, but I can arrange crating/shipping.
I'll take pictures of anything just let me know.
74 D block 351w 9.5 deck .30 over
Trick Flow R heads stage 2 port/polish and valve job
Beryllium exhaust seats
2.08 intake valve, 1.60 exhaust
Comp cams endure x super link bar solid lifters
1.55 diameter valve spring with 10 degree locks and 7/16 studs
Eagle 4340 forged Crank shaft
Eagle 4340 forged H-beam rods
JE forged flat top pistons
Fully ported Super Victor intake
Comp solid roller measuring..
intake .713 lift
exhaust is .714
duration on intake at .50 is 248
exhaust is 254
the lobe seperation is 112
intake center line is a 108
7 quart Canton oil pan and pick up with a melling hv83 oil pump
Edelbrock chrome water pump
ATI super dampener
ARP head bolts
Crane gold 7/16 stud rocker arms
Comp cams push rods part #7780 the length is 8.850 with a wall thickness of .080 5/16 diameter
Cloyes true roller timing chain and gears
10.5.1 compression.
completely new oil pump,distributor gear,springs,rings,gaskets, main and rod bearings.
