I'm thinking about swapping out the 302/C4 for a 390/C6 in my '68 Fairlane.
I've got a C6 trans. in the garage, does the 390 require a special bellhousing?
And what about the driveshaft, it'll probably need to be replaced with a different length right? The car has an 8" rear in it.
Yes the Fe style bellhousing is a different bolt pattern than a small block C-6(if thats what you have) so you will need a C-6 specifically for an FE engine.I think the driveshaft will probably need to be shortened but not 100% sure on that one.
1968 mustang 306,stock ported heads,650 Holley DP,weiand xcellerator intake, Comp cams Magnum 292,[email protected] and 518L,heddman headers,4speed with a 4.11 detroit locker.13.69 at 101 mph.
<font size=-1>[ This Message was edited by: frdnut on 3/1/06 2:33am ]</font>
