Hey got my first FE in a 72 f250. Now that I got all the exhaust leaks fixed I noticed that the right side sounds like the lifters are tapping and the left side sounds normal. Is that normal for an FE? Got plenty of oil pressure and of course oil.
How is that done with hydraulic tappets?When you have it off, rotate the engine until you get each set of valves closes and check for gaps between the rocker tip and the valves first off.
He is looking for ROOM. If there is room to place a feeler gauge between the stem and rocker tip, there is a problem with that lifter...
