I thinking to build a 393 and these would be the parts that I use, I would like to hear your views on this
- Scat 9000 3.85 crankshaft model 942-9351W10
- Summit Stage II 351W connecting rods with ARP bolt modelSMS-5-48-05-121
- Stock non roller Block 351W
- Sealed power aluminum flat top hypereutectic cast pistons and moly rings, 4 valves reliefs, pins are press only, coated skirt
- Procomp aluminiun heads, valves 2,02 and 1,6, springs 1.46 with internal damper, (springs and valves are made in USA) 210 cc and 60cc combustion chamber,
- Comp Cam xtreme seria hodraulic flat tap 284 Valve lift @ 1.6:1 in 0.541 ex 0.544, 110 Lobe, RPM operating rang 2300-6500
- BDR stall converter 2500/2800, BDR brand fod AOD transmission
- AOD transmision
- 8.8" 4:10 rear end
- Car is a mustang 1983
