I want to put together a 393 stoker, with limited funds. Going more for a reliable street driven engine not a drag car. I know I'll need a 3.85" stroke crank, have heard that the stock 351W rods work, and that 302 pistons w/1.6" comp. height should be used.
This will be built on a newer block with a 9.5" tall deck, not bored,
GT40-P heads cleaned up with a little porting, 61cc chambers.
Long tube headers with 1 5/8 primaries
Cam will be around 0.510 +/- lift but I haven't picked that out yet.
My questions are:
Are the 351W rods reliable, up to around 450 fwhp?
Can I use a set of Ford forged pistons from a 5.0 HO motor? I can't find anywhere what the factory Ford 302 piston compression height is so if anyone knows I'd appreciate it.
These two things would keep my costs way down but I want this to be a reliable motor, spin up to 6000 and no more. I'm planning on ARP bolts on the factory rods if I can use them.
If anyone is interested in my .030 over 302 (roller motor) let me know, it's got about 200 miles on it now & runs excellent just isn't enough for my 3700 lb car.
don
[email protected]
or
[email protected]
The truck rods will work fine for a lower RPM budget build. With the 393, you don't have to turn it that hard anyway...they are pretty torquey down low. But that said, I have had 2 failures in 2 separate engines that stemmed from using stock rods...both times the rod broke in the same place. But, keep in mind that one was a 600+ HP 7000 RPM race engine and the other was something that I build and the guy sprayed the daylights out of it.
I've got a set of truck rods that need to be finished...need new bolts and resized, but I polished the beams and clearanced the sides of the bolt bosses for camshaft clearance. Let me know if you're interested.
"it is better to appear ignorant than to open your mouth and remove all doubt"--Mark Twain
<font size=-1>[ This Message was edited by: mavman on 4/19/06 10:32am ]</font>
