Hi Guys,
I now have the bottom end of my 393W build complete & am about to start the build of the top end. Can anyone advise a logical sequence to this build or recommend a good article?
I will be installing a fully built set of AFR 185's & I will also be fittings a set of scorpion 1:6 billet rockers.
The cam is a comp cams XE284 hydraulic flat tappet.
My priorities are:
Establishing correct pushrod length, (already have an adjustable pushrod length checker).
Checking piston to valve clearance, I understand the best method is with the use of modelling clay?
Setting up correct lash.
Setting up correct valve train prior to my first dyno pull.
I have a vague understanding of the theory behind the processes above but need some technical guidance detailing the logical steps required & also the detail surrounding the steps above..
Its a big ask but am hoping somebody can advise me to allow me to complete the top end build as well as I have hopefully built the bottom end!!
Cheers,
Martyn.
Hi Guys, Jam,
Thanks for the info.
To answer Jams question the rockers are 7/16 stud mount.
Regards,
Martyn
