I HAVE A VT COMP SHORT BLOCK WITH STAGE 2 HEADS AND CAMS SUPERCHARGED.SOMETIMES AT AN IDLE IT SHOWS 0 OIL PRESSURE.NO NOISE SO IT HAS TO HAVE PRESSURE.THE ONLY SPEC THAT FORD SHOWS IS 15-20 PSI AT 2000 RPMS. I CHECKED PLUGS IN BACK OF HEADS.IS THERE A CHECK VAVLE IN FILTER HOUSING THAT COULD AFFECT THAT ? SOME TIMES WHEN YOU START IS SHOWS 40 PDS.SOMETIMES 10 PDS.IT IS A NEW MANUAL GAUGE. THIS CAR HAS BEEN DYNOED SEVERAL TIMES AND RAN AT TRACK LIKE THIS.IT HAS ABOUT 6000 MILES ON MOTOR.
