Great ideas how to make old stuff sound better.
Now that you all have inspired me to want to try to make the 3 speaker setup work in my 66 LTD stock AM radio, I have to ask the basics. (I am decent mechanically with my car, but some of the radio wiring we are talking about here, just not as familiar with.)
I did my research on fader switches, and do remember them, been awhile since I had seen one, and found a couple on ebay,
Switch Assy. Tape Player Fader Control, 1966 Cyclone Fairlane Lincoln Galaxie | eBay for example.
My mind is not wrapping around how I am going to put the those small speakers in the holes in the rear package trays and then connect them to a fader switch- from the wiring perspective. In my mind, I would mount the rear speakers in the back seat area sail panels where they have mounting holes behind the bezels of course, then run the wires through the rear and front door sill trays towards the front dash area. (Of course, I would have to rig up some wires fairly long that could accommodate the rear speaker plugs. Those rear speaker wires are only a few inches long, so I have lots of distance to cover for those wires to reach the front under dash area. The car has not had rear speakers previously. )
Once I have those wires run under the sill plates from the rear speakers on each side and snaked under the dash to the fader switch, I am going to have figure out where and how to plug into the fader switch plugs. The extension wires I will need to create aren't going to have plugs on them to connect to the fader switch plugs. (I could connect some simple plugs if I had to from other harness I have laying around). Where those rear speakers would plug into on the fader switch I could figure out through trial and error. I am guessing then I would have to plug my speaker wire from the AM radio(just a 2 plug m/f lead) lead from the radio into the fader switch somewhere on that harness. Then lastly, I would take my original existing AM front underdash speaker wire, that used to plug into the radio lead directly in my one speaker setup, now that will plug into one of the fader switch leads. And the existing AM radio would have enough power to run it all with my old school original speakers?
I found this harness on ebay also, a bit pricey. Again, I am running a stock AM radio, so I am thinking the plugs for the AM/FM are different than the AM only on those fader harness. This harness probably seems not comparable for what I am working with, but is interesting.
This is a very rare find. Every bit of the uncut loom is included including the pigtails to the speakers. Clean and pliable with no splices and we tested the switch.
www.ebay.com
Anyone have the patience to educate me on if I am making it too complicated or just have enough knowledge to maybe stumble into making it work? (a simple stick figure diagram would work in my case!)
