Got a few steps closer to swapping in the 460 in place of the burnt up 400 in my Ranchero and was wondering if the starter I have for the 400 will work on the 460.
I swapped a 460 in place of a 400 on a 1973 LTD... but it was around 25 years ago. Everything stock. I remember cussing Ford, as it seemed like everything that could possibly be different, was. Sure, they both shared the same bellhousing, but that was about it! It was a good thing the boneyard I was dealing with had a parts car for all the little trinkets, or it would have been a major PITA.
But, keep in mind... I was in high school while doing this, so it may not have been quite as big of a deal as I remember. lol But, Ford did seem to change a lot of stuff that they didn't need to when it came to interchanging stuff.
Good Luck!
Banned
400 starter will work ok , if the oem 460 trans is used a bolt and nut will be used in the upper hole
I used a manual 351C starter on my 460 C6. Had no problems with meshing of teeth.
