For sale is 406" sbf drag race engine:
Dart Sportsman 9.5 deck 4.155 bore
eagle 3.75 crank
grp alum rods
diamond custom pistons
lsm BIG solid roller cam
bushed lifter bores
55 mm cam bearings
ultra low tension rings
jesel belt drive
isky lifters .904
jesel rockers
victory titanium valves
tfs high port heads-2.15/1.59 max ported
edelbrock 2828 manifold-ported
stef's custom alum pan
innovaters west balancer with built in crank trigger
msd distributor
electric water pump
moroso external oil pump
moroso vacuum pump.
15.5-1 compression
Engine runs on Q16/c25. Professionaly built by Mike Curcio at MCRP in Easton PA. This engine with a good 3 speed will go 8.60 n/a @2800 lbs. This engine is fresh ready to go.
$13,500 less carb.
or trade for a aftermarket blocked 427 FE
Discussion Starter · #4 · (Edited)
The motor will be dynod in about a month at MCRP in Easton PA. Should make 820-850 on q16
i have timeslips of 8.90-9.0s before upgrading a bunch of stuff
new stuff on it is, camshaft, pistons, rings, manifold, valve springs, cam bearings, oil pan (large kickout), main and rod bearings. All other parts have 15 passes since new.
old setup made [email protected].
We found the camshaft needed an upgrade and it would net us a huge gain from the old one.
Shortblock turns over like butter by hand.
Damn, I need to find a 69 RS/SS Camaro to gut.... Or maybe a 70 AAR Cuda...:D:D:D
Discussion Starter · #8 ·
and the dyno said ?
9.00 to 8.60 is about 100 hp
Dyno isnt up and running yet. the car went 8.90 with a 2 speed. As stated with a good 3 speed and new parts in the engine, it will be faster. HP isnt the only factor in lowering et's.
the car 60' in the 1.27-1.28 range and the 3 speed will get it closer to 1.20 if not faster. That alone is huge.
