Would like to get some comments on my proposed engine build to know if I have the right combination. Here are the specs
70's 351w block
Eagle rotating assembly
  • 4.0 stroke
  • Forged pistons +26 dish
  • Cast steel crank
  • I-beam rods
AFR Heads
  • 205cc
  • 58cc combustion chamber
Comp cam - XR288RF-HR
  • Duration @.050 236/240
  • Valve lift .555/.576
  • Lobe Sep 110
  • Aluminum roller rockers 1.6 - 7/16 stud
  • Link bar lifters
Edelbrock Intake
  • RPM Air Gap
Holley Carb
  • 750 CFM HP
Any and all comments would be greatly appreciated
Kirk
klaw64 did you ever build this motor? I'm wondering what combination you ended up going with. I will be using the Comp cams Extreme Energy XR288RF-HR cam in my 408w. Wondering if you went with it and how you like it.
