1 - 20 of 32 Posts
i found a fe motor in a old speader truck valve covers are aluminum and the intake is too they have 427 HP on them But the block is not cross bolt but has 352 on the front did they make 427 without the cross bolt # on heads are C7AE-H can anyone ID what i found i have to buy the whole truck to get the motor $500.00 is that to much?
I would measure the stroke of this engine. Without crossbolts, it is not a 427. Someone has likely put the intake and valve covers on it. Pull #1 or #5 spark plug out, go to top dead center, take a measurement with a 9 inch 3/8 extension or a wooden dowel rod, make a mark, and then got to bottom dead center, take another measurement and mark the dowel rod. Measure between the two to give you the stroke of the engine. i.e. 3.784= 390, 3.784 with crossbolts= 427, 3.98= 428/410/406 lastly a 3.50= 352/360. I just found a 410/428 in an old truck the other day, so don't be surpised as to what you find. Take the measurements several times to insure that you have done this correctly. Is it running? That would also help to determine a fare price. Let me know if you have any other questions.
1965 Galaxie 396 FE, toploader, 3.70 posi
<font size=-1>[ This Message was edited by: galaxiegt on 3/24/06 8:50pm ]</font>
Doesn't sound like a 427, like the other guys said because of the cross bolting. The heads # I can't find in my #'s cross reference book, they go C6AE to C8AE, not C7AE, but the other numbers suggest a 428 4V head. Because it is a truck, maybe it was the odd ball 361 or 391 engines, also FE's. Pretty much everything is interchangeable from one FE to another.
IIRC: The 1968 W-code 427ci engines were not crossbolt mains. The remainder were crossbolt on the center three main bearings. The W-code engine also had hyd. lifters.
Ray
<font size=-1>[ This Message was edited by: rayell on 3/25/06 5:02am ]</font>
<font size=-1>[ This Message was edited by: rayell on 3/25/06 5:04am ]</font>
Discussion Starter · #10 ·
where do i fine on the motor if it is a W-code the best i can tell the stoke is a 3.98 the number on the back next to flywheel 352 27 the code by the oil filter WI the owner is going to let me take the heads off I will let Yall know
Check the flywheel, if there is a counterweight welded on the engine side of the flywheel AND it has a 3.98 stroke, grab it.
Depending on the date code it will be a 428 or 410. 410 only available 66,67 Mercury and yes ALL 427 passenger car blocks were crossbolted.
Tony P.
<font size=-1>[ This Message was edited by: UTRY on 3/25/06 8:48pm ]</font>
· Premium Member
Tony P.
Wrong. Better do some more research as there were a few passenger car 427 blocks that weren't crossbolted that slipped through the assembly lines. Ford did some really strange things, especially with the FE Engines.
If I'm wrong in regards to the non crossbolted passenger car 427s. can someone post some documentation , shop manual info, tech articles or pictures, I think everyone here would like to see them, especially me. By the way Jeremy I have done a lot of research on this and would consider proof of a 2 bolt 427 continued research.
Tony P.
<font size=-1>[ This Message was edited by: UTRY on 3/26/06 10:49pm ]</font>
1 - 20 of 32 Posts
