Looking at buying a 1972 Mustang fastback. I had the pre-purchase motor vehicle inspection compression test done on the 429 engine (unknown origin - Engine No. 1J227610) in it. The average psi over all the cylinders was 125psi. Is that low? I’ve been told it is and that the heads might be worn or the head/inlet gaskets might be compromised. There was also a lot of brown sludge in the radiator reservoir. It wasn’t oily but I can’t explain its origins?
Any help you can give me on my enquirers would be truly appreciated👍
Cheers
Carl
Cheers
Carl
