I have the opportunity to purchase a 429 SCJ Motor and C-6 Tran with headers with a vehicle I am purchasing.
Block Code#DOVE-A Heads Code#Dooe-R.
I was told it fits a Mach 1
Trying to figure what this worth???????
Where could I advertise this?????
Heads # right, D0OE-B should be block for an SCJ. Probably CJ or PI block. Look closer, sometimes the casting numbers are hard to read.
Block is and should be a DOVE-A casting number with four bolt mains. DOOE-B was the nodular case casting number. Depending on condition , carb , dist , valve covers, sight unseen around $5,000. Trans about a grand. Where are you located?
Randy
Check the Servo for an "R" on it. If this is from the same vehicle and date matches, to the right person, some nice $$$$. More complete the engine, dist, exh/int manifolds, etc, the better. Check all build dates and any tags.
