1 - 16 of 16 Posts
could anyone tell me the difference between the two. the only diff i see is that one has mech cam, diff carbs,headsand intake but is everything internal the same????
I'd read the CJ/SCJ had wristpins offset to help straighten the rod earlier on the power stroke- checked my old 69 copcar engine last week, its got offset pins too.
One parts book I looked in years ago said my heads were CJ castings, but the valves were smaller? C8VE-A if I recall correctly...think the early C8/D0 heads were all basically similar closed chamber/very high compression with valve diameter machining the biggest difference...but dunno, just a guess. I remember looking up numbers on this motor long ago(1981 when I wrecked car/rebuilt it) and 429 compression varied from 10:1/10.5:1/11.3:1 depending which book you looked in...
near as I can tell, just about ANY Ford engine I've torn down has offset wrist pins.
CJs and SCJ's had a different rod, which is the same rod as a truck rod.
Thats about all I know
429 CJ/SCJ Blocks
The Four Types of 429s
(Thanks to Dan Davis)
First was the base 429, known as the Thunder Jet (TJ). It came in T-birds and full size Fords in the late 60's and early 70's. Typically 360 horsepower. By far and away the most common -- they made 100,000+ of these. Can be ID'd be block casting numbers of C8SE, C9VE, D0VE, D1VE among others and head casting numbers of C8SE, C9VE, D0VE among others.
Then there was the 429 Cobra Jet (CJ). It was built only in 1970-71. It was only installed in mid-size (1970-71) and pony cars (1971 only). 370 HP (likely underrated), thick strong blocks and massive ports int he heads. ID'd by D0VE-A and D1VE-AA casting numbers on the block and D0OE-R on the heads. No other numbers are CJ. Not too common, maybe a total production of 15,000.
The 429 SCJ was a stronger version on the CJ. The difference was forged pistons, solid lifter cam and four bolt mains*. The rest of the info is the same. Even less common with a production of maybe 3,000.
The baddest of them all is the Boss 429. It was rated at 375HP (grossly underrated). It came in special Mustangs (and 2 Cougars) in 1969-70. It had four bolt mains, aluminum hemi-style heads and looked like no other engine. ID by casting number on the block of C9AE. The heads ID themselves. Very rare and very expensive as only about 1,200 were made.
(* Correct for 429 SCJ Torino. On 71 429 SCJ Mustang, both 2 and 4 bolt mains were possible - JB)
I would list the link, but for some reason it gets screwwed up... hate to not give credit to the author.
<font size=-1>[ This Message was edited by: Beoweolf on 7/14/06 11:05am ]</font>
One of my '70 Ranchero GT's has a 429 C9VE engine
On 2006-12-23 11:00, aj100 wrote:
Hi All,
I have a D1VE-A 429 block. Is this a CJ block?
Thanks,
AJ.
According to the information on the link. ONLY D0VE-A and D1VE-AA casting numbers on the block signify CJ/SCJ blocks. A visual indication should clear up any doubt - go to the link and read the information.
http://429mustangcougarinfo.50megs.com/decoding.htm
429 CJ/SCJ Main Bearing Webs
In addition to the casting numbers, CJ/SCJ blocks were signified by having thicker main bearing webs than the standard 429 blocks. The webs on the CJ/SCJ block get thicker, stepping from 1” to 1.4” near the intersection of the web to the sidewall while the base 429 block webs are noticeably narrower*.
* see the pictures on the link/web site, its obvious what they are talking about, once you see the picture.
Also the CJ/SCJ webs are taller and machined to the same height as the oil pan rail. By contrast, main bearing webs on the base 429 (Thunder Jet) block at right get thinner as they meet the sidewall and are not as tall as their CJ/SCJ counterparts. Instead they are as cast and end below the oil pan rail.
Two -vs- Four Bolt Mains
Since the two or four bolt caps were added after the block was cast, the casting number WILL NOT tell you if it is a two or four bolt main block. What it WILL tell you is that the block has thick main webs, making it a CJ/SCJ block (PI too).
Finally - 2 things to remember. First there are no "bad" LIMA blocks, just some are better than others. Second, these cars/engines are 40 years old and they were performance engines. It is likely that somewhere down the line the original engine may have been replaced, swapped, stolen, moved to another car... drop the oil pan and check the main bearing web to be sure.
<font size=-1>[ This Message was edited by: Beoweolf on 12/24/06 4:33am ]</font>
Banned
The very early CJ/SCJ blocks were both 4 bolt mains, 2,3,4. After a certain point in very late 69, 70 production year, the CJ went to a 2 bolt cap. Then for 71 production they both had the 4 bolt mains again. Crank is a little better quality on CJ/SCJs, rods are diff with the "football" rod bolts. CJ had cast pistons, SCJ had forged, same comp, 11.3-1. Heads themselves are the same, only real difference is the rocker are studs. CJ is torque down, SCJs is 7/16" adjustable with locknut. SCJ mechancial cam, CJ hyd. SCJs noramlly had a 3.90 or 4.30 gear ratio with and oil cooler. But if it was ordered different, you never know what you might find. The CJ was also labeled Police Intercepter in 70-71 then they got their own heads in 72+ along with becoming a 460 to. When the CJ/SCJ engines endend in the Spring of 71 Ford used the blocks on the shelf to go into anything. So don't be surprised to find one in a wagon. Easy way to clear the shelves. IMAO, best setup is, a 460 with forged pistons in a SCJ/CJ block, with the regular heads with CJ/SCJ valves and more modern valve train setup. I had a 71 Torino Cobra, SCJ, 4sp. and it was a dog under 3000rpms. Once you had it rolling it really came on. 460 with the smaller ports, ported out on the exh side mainly, bigger valves, is a strong tough to beat setup.
I'm getting a 429 Thunderjet for my Torino, called summit guy said he never heard of one, Guess I'll have to get numbers and go that route,is there a website with any info on the thunderjet?all replies appreciated!
429-460 "Lima" engine
Basically, ALL 429's are Thunderjets, EXCEPT FOR:
* 429 Cobra Jet 70-71
* 429 Super Cobra Jet 70-71
* 429 Boss 69-70
* 429 Police 72
The best 429 TJ are from 1968-71.
These are cast piston [not same piston as 429cj but cast, 4 valve reliefs], broached rod / square bolt head. Small port heads, small 2.06 x 1.66 valves, small intake, small cam [190-202 at .050 lobe], small exhaust manifolds, 600cfm Autolite carb on top. 10.5 cr. They were rated at 360hp but in my opinion made about 320-325 gross hp, which is about 240-250 net hp during those years. The small cam and crappy exhaust ports really hurt the 429TJ.
The 429cj added
* 4-bolt mains sometimes but any Lima block is plenty strong
* football head rod bolts for a stronger rod
* cast pistons with only 2 but bigger valve reliefs
* Bigger heads with sewer-pipe sized intake ports and a little better exhaust ports, 2.24 x 1.73 valves. 11.3 compression
* a decent cam at 220-230 duration
* A taller big port intake with a GM Quadrajet on top about 700cfm
* Better exhaust manifolds
* About 405 gross HP. MAYBE 370 net HP if you had a really good loose engine and the cold air option and no extra belt drives. Usually about 330 net HP.
The 429scj added to the CJ:
* forged pistons, also 11.3 CR
* adjustatle valve train [some early 429cj had this also]
* solid cam at 230-230 duration, basically same cam Ford had run in the old 390HiPo, 406, and 427-4v.
* Big intake, iron, same as the CJ but with a Holley 780 pattern
* Holley 780 on top
* About 410 gross HP, again MAYBE 370 net in a really well built example, most were 340-350 net HP.
You can make the 429TJ into about the equal of a 429CJ/SCJ pretty easy and cheap:
* Put the bigger 2.24 x 1.73 valves in your base heads
* Use the 429scj iron intake [the ports dont match but it doesnt matter], or a modern aluminum equivalent
* 1-7/8 headers
* Either a comp 270H or comp 270S cam or similar
* A 780 Holley or 800 double pumper on top
also 460ford.com is a good site for this engine.
I had a few Torinos back in the 1970s when they were dirt cheap, fun cars. Paid $15 for my first complete shaker assembly. The trim ring for the hood was an extra $10 new, that was the pricey part! We just threw all the snorkels in the trash. LOL.
* 429 Boss 69-70
* 429 Police 72
The 429cj added
* Holley 780 on top
* 1-7/8 headers
good info- but there mighta been some odd mixes in there too- my 69 429 came from a 2 door cop car(dad bought it from pd auction in 1971, it was their 'undercover' car- a 2 door with cop car goodies. car had a autolite carb, 2.06/1.66 valves, but only 2 valve reliefs on pistons- also I read that all the police engines had wristpins offset- these were too- but replacement/service pistons were supposedly 4 notch/center pinned... I wrecked the car in 1980, still have the engine...just went out to doublecheck valve diameters, hadnt even so much as touched it since taking it back apart 5 yrs ago(I had reringed/bearinged it when I was 16, after the wreck- test fired it and it sat till 5 yrs ago- luckily it was well sealed, and I had flooded it with oil after test firing it in '80, found no rust inside...) eventually its *still* slated for my 69 mustang
Strange mixes? They actually put the 429CJ, 4spd in about 1200 71 LTDs. Real screamer just a bit heavy. Watch the movie "White Lightning" and you'll see one.
1 - 16 of 16 Posts
