I had recently dynoed my sbf 445 and i thought i would share the results.
4.100 crank
6.250 rod
4.155 bore
Victor 7721 heads
15 to 1 compression
nasty solid roller set up for NOS
Super Victor
1450 cfm carb.
Moroso Vacume pump.
Considering that i blew the head gasket on the 8th pull and continued on, motor made 799 hp @ 7100 rpm & 633 tq. & 6100 rpm. I know the motor has more, but the motor was not sealing on the outside due to oil leaks and the vacume pump would not pull as much vacume. Also, that's with a Nos cam , which i made N/A pulls on the dyno.
800 N/A SBF
<font size=-1>[ This Message was edited by: 93lx on 4/7/06 8:13am ]</font>
4.100 crank
6.250 rod
4.155 bore
Victor 7721 heads
15 to 1 compression
Super Victor
1450 cfm carb.
Moroso Vacume pump.
800 N/A SBF
