I fired up a fresh 460 on my test stand today, It ran for just a short time before I noticed coolent running down the side of the block. I shut it down and inspected the issue, sure enough the coolent was seeping out of the headgasket area on both sides, in the rear of the engine. I've got three ideas of what went wrong, I've the block and heads have both been decked, so I don't think a warped surface is the issue. The first is, that perhaps I installed the head gasket upside down, would this cause it to leak? The second reason I can think of is that maybe since material has been taken off the block and heads, that the alignnment dowel is a bit too tall now. The final issue is that maybe the head bolts need sealer on them? This is the first 460 I've built, maybe I'm missing somthing? Anyone have any suggestion?
