Trying to run this 12v(?) clock on house current. Have a 12.5VAC regulated power supply. Is this the right thing? How do I wire it? Needs a light bulb, same wire as clock? Any help appreciated.
yes that power supply may work but hook it to a 6 volt battery first using the directions bellow and se if it tells time corectly if it only shows about 25min. on the hour hook it to the 12.5 volt supply. directions to hook up: take the single wire from the clock and atach it to the + terminal on the supply then run another wire from the metal case of the clock to the - terminal of the clock.
